In today's session I sealed the fuel pickup tube fitting and B-nut anti-rotation bracket to the fuel tank access panel, see image 1. Then I installed the fuel quantity indication system capacitance plates and sealed the electical wires at the terminal connections, see image 2. Finally I made a cover plate for the outboard tank bulkhead tooling hole and sealed it in place, see image 3. I also sealed in the fuel vent tube fitting into the tank inboard bulkhead.
